Implementing pkg EducationLaz corrupts "Options" 12 years 11 months ago #4772
  • Bernard Asher
  • Bernard Asher's Avatar Topic Author
After installing the EducationLaz 1.01 package you cannot choose the "Tools - Options" menu choice anymore :woohoo: It fails with the message "Unknown/Unsupported Targa image type".
This didn't happen in CT 4.4, but now in 4.6 it happens, both in Win32 and Win64 versions.
Can anyone help me with this?
Last edit: by Bernard Asher.
Implementing pkg EducationLaz corrupts "Options" 12 years 11 months ago #4910
  • Bernard Asher
I can understand that no one responded to this bug report. You have to use the Education package to fully understand its virtues. The one most important feature is its ability to make components and tabs from the component palette invisible. For anyone who likes a small palette of just the components used in his projects, the Education package is indispensable.
So, please Mr. Sternas, can you have a look at this?
Last edit: by Bernard Asher. Reason: spelling corrected
Implementing pkg EducationLaz corrupts "Options" 12 years 11 months ago #4912
We will try Sir
Implementing pkg EducationLaz corrupts "Options" 12 years 10 months ago #4915
  • Bernard Asher
I wouldn't mind debugging this problem myself. However I have no idea how to debug the IDE (I rebuilt it already with Dwarf2 debugging options).
First of all I would have to block the system from stripping the debug information.
If I open the project "C:\codetyphon\typhon\ide\typhon.lpi" and try to run it, it says:
No program file "C:\codetyphon\typhon\typhon.exe" found
which is true but very unhelpful.
If I try to build it, it says:
The program's compiler options has no compile options
which is wrong and even more unhelpful.
So, what is the right way to debug the IDE?
Thanks.
Implementing pkg EducationLaz corrupts "Options" 12 years 10 months ago #4917
This is NOT so simple Sir
Typhon IDE is NOT a simple program, it's an "Executable System"
My suggestion is to use "Build Typhon" with your "debugging profile" from Typhon IDE/Tools
Implementing pkg EducationLaz corrupts "Options" 12 years 10 months ago #4919
  • Bernard Asher
sternas wrote: My suggestion is to use "Build Typhon" with your "debugging profile" from Typhon IDE/Tools
I had already done that. But that does not bring me to the point where I can actually debug the IDE
Implementing pkg EducationLaz corrupts "Options" 12 years 10 months ago #4977
  • Bernard Asher
sternas wrote: We will try Sir
How is it going?
Best wishes and lots of happiness in 2014 :)
Implementing pkg EducationLaz corrupts "Options" 12 years 10 months ago #4984
  • Bernard Asher
The problem with the Education package stems from a possibly invalid icon in the dwScript package. Ignoring the exception that results from it cures the problem.
The Education package still does not display the correct icons for any components, though.
This is the patch:
Module EduCompPalette:
procedure TEduCompPaletteFrame.FillComponentTreeView;
Line 174:
//    if ResHandle <> nil then                             // BA
//      Image := CreateBitmapFromResourceName(HInstance, ResHandle.Name) //BA
      if ResHandle <> nil then begin                       // BA
        Try                                                // BA
        except                                             // BA
          Image := nil;                                    // BA
        end;                                               // BA
      end                                                  // BA
Implementing pkg EducationLaz corrupts "Options" 12 years 10 months ago #4985
we will check and report here
