[LAB] Cindy components 8 years 8 months ago #11044
  • chor
  • chor's Avatar
Hi Sternas, thanks for looking into this. I am using v6.00 with GTK2, hosted by Ubuntu 16.04 64bits, is there a patch I can apply to my current setup? Attached is an 'about' screen dump.
Many thanks,
Chor
[LAB] Cindy components 8 years 8 months ago #11045
  • Thank you received: 1132
unit cyBaseSpeedButton.pas
replace
procedure TcyBaseSpeedButton.DrawCaption
with this code
//--- ct9999 -----------------
procedure TcyBaseSpeedButton.DrawCaption(aRect: TRect; aState: TButtonState; Hot: Boolean; GlyphExists: Boolean);
  aAlignment: TAlignment;
  aTextLayout: TTextLayout;
  DrawStyle: LongInt;
  TmpFont: TFont;
  xTextStyle:TTextStyle;
  if Caption = '' then EXIT;
  aAlignment := taCenter;
  aTextLayout := tlCenter;
  if GlyphExists
  then
    case Layout of
      blGlyphLeft:   aAlignment := taLeftJustify;
      blGlyphRight:  aAlignment := taRightJustify;
      blGlyphTop:    aTextLayout := tlTop;
      blGlyphBottom: aTextLayout := tlBottom;
  DrawStyle := cyGraphics.DrawTextFormatFlags(0, aAlignment, aTextLayout, FWordWrap);
 // DrawStyle := DrawTextBiDiModeFlags(DrawStyle);      ct9999
  if FCaptionOrientation = coHorizontal
  then begin
    xTextStyle:=Canvas.TextStyle;
    xTextStyle.Alignment:=taCenter;
    xTextStyle.Layout:= tlCenter;
    Canvas.TextRect(aRect,0,0,Caption,xTextStyle);
  end
  else begin
    // Use Canvas.Font because already assigned on DrawButton and can be changed on BeforePaint event !
    TmpFont := cyCreateFontIndirect(Canvas.Font, FCaptionOrientation);
    try
      Canvas.Font.Assign(TmpFont);
      cyDrawVerticalText(Canvas, Caption, aRect, DrawStyle, FCaptionOrientation, aAlignment, aTextLayout);
    finally
      TmpFont.Free;
The following user(s) said Thank You: chor
[LAB] Cindy components 8 years 8 months ago #11059
  • chor
  • chor's Avatar
The patch has side effects on some of the cindy button, have worked round it for now. Many thanks for all your help. Really appreciate all the wonderful work you are putting into CodeTyphon. Looking forward to the new release!
Best Regards,
Chor
[LAB] Cindy components 8 years 8 months ago #11060
have fun
