Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11264
  • Hans-Peter Gygax
  • Hans-Peter Gygax's Avatar Topic Author
In "Project Options", I have set "TargetOS" to "Win32" and "Target CPU Family" to "i386".
When I try to build, I get:
Compile package adFCL 6.3.1: Success
Compile package bs_Utils 6.3.1: Success, Hints: 17
lazutf8.pas(509,44) Hint: Mixing signed expressions and longwords gives a 64bit result
lazutf8.pas(519,53) Hint: Mixing signed expressions and longwords gives a 64bit result
lazutf8.pas(524,33) Hint: Mixing signed expressions and longwords gives a 64bit result
lazutf8.pas(530,44) Hint: Mixing signed expressions and longwords gives a 64bit result
lazfileutils.pas(108,71) Hint: Parameter "Rights" not used
compwriterpas.pas(1330,21) Hint: Mixing signed expressions and longwords gives a 64bit result
compwriterpas.pas(1330,21) Hint: Converting the operands to "Int64" before doing the multiply could prevent overflow errors.
compwriterpas.pas(1335,32) Hint: Mixing signed expressions and longwords gives a 64bit result
lazlistclasses.pas(1236,43) Hint: Mixing signed expressions and longwords gives a 64bit result
lazlistclasses.pas(1639,20) Hint: Mixing signed expressions and longwords gives a 64bit result
lazlistclasses.pas(501,126) Hint: Mixing signed expressions and longwords gives a 64bit result
lazlistclasses.pas(611,116) Hint: Mixing signed expressions and longwords gives a 64bit result
lazlistclasses.pas(652,71) Hint: Mixing signed expressions and longwords gives a 64bit result
lazlistclasses.pas(654,143) Hint: Mixing signed expressions and longwords gives a 64bit result
lazlistclasses.pas(799,27) Hint: Mixing signed expressions and longwords gives a 64bit result
Compile package adLCLBase 6.3.1: Exit code 1, Errors: 1, Warnings: 1
Warning: windres: can't open file `TCalendarPopupForm': No such file or directory
calendarpopup.pas(183,1) Error: Error while compiling resources -> Compile with -vd for more details. Check for duplicates.
The project is just a test project, it contains a TVirtualStringTree and a button.
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11265
Any project for test, Sir
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11271
  • Hans-Peter Gygax
So sorry for the long delay. Here's a ZIP file with my test project.
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11272
just uncheck
"Use additional compiler config file..."
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11273
  • Hans-Peter Gygax
Thank you, but unfortunately that didn't change anything for me.
Could the reason be a mistake I made in CT Center ?
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11274
I don't know
but
my suggestion is to "Remove and Build All" from CTCenter
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11275
  • Hans-Peter Gygax
I have now done so, but unfortunately the problem remains unchanged.
I'm attaching a screenshot showing my CTC.
Last edit: by Hans-Peter Gygax.
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11276
Did you have any FPC or Lazarus Installations in your PC ?
We want more info
Please, post here your PC "Path" string only
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11277
  • Hans-Peter Gygax
Thank you Sternas,
I indeed had a Lazarus installation, plus some Embarcadero leftovers. I removed all of that, but now I'm getting:
Compile package adFCL 6.3.1: Exit code 1, Errors: 1
Error: ppc386.exe can't be executed, error message: Failed to execute ""ppc386.exe" -B -Twin32 -MObjFPC -Scghi -O1 -g -gl -l -vewnhibq -FuC:\codetyphon\typhon\packager\registration\ -FUC:\codetyphon\typhon\packager\units\i386-win32\ fcllaz.pas
The CTC "Get System Info" aborts (the output window closes after a split second).
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11278
For your Path
please go to CTCenter=>CommandBox page
to see the "Get System Info" result
Please Build FPC32
and post here the Action Log info (please zip first)
We try to get more information to help you...
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11279
  • Hans-Peter Gygax
After adding "C:\codetyphon\fpc\fpc32\bin\i386-win32" to my path, ppc386.exe now executes and I can build and launch my project.
Is this normal ?
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11280
  • Hans-Peter Gygax
Correction: I can only launch it without the debugger.
Here is the system info output:
CTCenter 6.30
for x86_64-win64-Win32/64
Start Action at 1/11/2018 12:16:27
           CodeTyphon System Info
Microsoft Windows [Version 10.0.16299.192]
OS Name:                   Microsoft Windows 10 Home
OS Version:                10.0.16299 N/A Build 16299
OS Manufacturer:           Microsoft Corporation
OS Configuration:          Standalone Workstation
OS Build Type:             Multiprocessor Free
System Boot Time:          1/11/2018, 10:43:24 AM
System Manufacturer:       ASUS
System Model:              All Series
System Type:               x64-based PC
System Directory:          C:\WINDOWS\system32
System Locale:             en-us;English (United States)
Total Physical Memory:     16,323 MB
Operating System is: 64 bit
OS Folder: C:\WINDOWS
Computer name: DESKTOP-OMQBER9
User Name: gygax
User with Administrator Privileges: "YES-- (ALL OK)"
User Settings Folder: C:\Users\gygax\AppData\Roaming
User Profile Folder: C:\Users\gygax
User Temp Folder: C:\Users\gygax\AppData\Local\Temp
All Users Profile Folder: C:\ProgramData
All Users Programs Folder:C:\Program Files
------- PATH ------
C:\codetyphon\fpc\fpc32\bin\i386-win32;D:\Tools\x64\vc14\bin;D:\Tools\x64\bin;D:\Tools\;C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\amd64;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\bin;C:\Program Files\NVIDIA GPU Computing To
Terminate Action at 1/11/2018 12:16:30
Total time: 00:00:02.838
ExitCode : 0
I'm compiling fpc32 now.
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11281
  • Hans-Peter Gygax
I have now re-built fpc32.exe, build output is attached.
I still cannot debug though, but maybe that is normal when cross-compiling ?
Building still only works when ../fpc32/bin/i386-win32/ is in the path.
I could probably work like this, even though I cannot debug directly.
Is there a way to have a project with separate "configurations", one for 64-bit, one for 32-bit ?
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11282
<<I still cannot debug though, but maybe that is normal when cross-compiling ?>>
Yes you must use gdb for win32 target : C:\codetyphon\binGDB\win32\gdb.exe
and
gdb for win64 target : C:\codetyphon\binGDB\win64\gdb.exe
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11283
  • Hans-Peter Gygax
That works, thank you.
Are you considerung extending the IDE options so that a different debugger could be configured for each target platform ?
Strange error when trying to build for 32-bit Windows using Typhon64 on Windows 8 years 10 months ago #11284
No yet Sir
