× General discussions, feature requests for CodeTyphon Project and discussions that don't fit in any of the other specific CodeTyphon forum categories.
Question XMLDocument UTF8 Problem
  • ct_user
  • Topic Author
  • Fresh Boarder
  • Fresh Boarder
9 months 4 days ago - 9 months 4 days ago #10941 by ct_user
XMLDocument UTF8 Problem was created by ct_user
By requesting a xml-result encoded in UTF8,
i found a problem concerning UTF8-Charachters.
in ct6.10 fine.
In ct6.20 char > 255 converted into ?
CT 6.10
function T_DVB_VIEWER2.GET_RS_VERSION: Boolean;
i : integer;
RESPONSE : TStringList;
SS : TStringStream;
XML : TXMLDocument;
NODE_ROOT : TDOMNode;
NODE_iver : TDOMNode;
// Get Data
RESPONSE := TStringList.Create;
Self.HttpGetText( Self.F_URL, RESPONSE );
SS := TStringStream.Create( RESPONSE.Text);
SS.Position := 0;
XML := NIL;
ReadXMLFile(xml, SS);
END;
SOLUTION for CT 6.20
i : integer;
SS : TStringStream;
XML : TXMLDocument;
// Get Data
SS := TStringStream.Create( RESPONSE.Text, tEncoding.UTF8);
SS.Position := 0;
XML := NIL;
END;
It should be a reason of how a TStringStream is now created without adding tEncoding.UTF8.
prior it works. now you have to extend.
take care
ct_user
Last edit: 9 months 4 days ago by ct_user.
9 months 4 days ago - 9 months 4 days ago #10942 by Sternas Stefanos
Replied by Sternas Stefanos on topic XMLDocument UTF8 Problem
thanks for your solution.
It's FPC source improvement
FreePascal SVN 36758 "TStringStream now observes encoding, bug ID 30508"
Info1
Info2
FreePascal bugtracker link
CodeTyphon use the latest FreePascal...
and we track->build->test FPC SVN source 2-5 times per day... :)
Last edit: 9 months 4 days ago by Sternas Stefanos.
The following user(s) said Thank You: ct_user
