How does CTC connect to server 11 years 5 months ago #7290
  • Johan
  • Johan's Avatar Topic Author
Can someone please explain how CTC does the connection to the pilotlogic server, when I try to update i always receive following output.
[INFO]: Download file, please wait...
--2015-05-13 07:54:58-- www.pilotlogic.com/codetyphon/current/zzctdirver.ctv
Resolving www.pilotlogic.com (www.pilotlogic.com)...
Resolving www.pilotlogic.com (www.pilotlogic.com)... 95.211.76.152
Connecting to www.pilotlogic.com (www.pilotlogic.com)|95.211.76.152|:80...
Connecting to www.pilotlogic.com (www.pilotlogic.com)|95.211.76.152|:80... failed: Bad file descriptor.
Retrying.
--2015-05-13 07:55:19-- (try: 2) www.pilotlogic.com/codetyphon/current/zzctdirver.ctv
Retrying.
Now when I point with my browser to the the address www.pilotlogic.com/codetyphon/current/zzctdirver.ctv I see the contents.
Thanks for your respone.
Regards,
Johan
How does CTC connect to server 11 years 5 months ago #7291
the procedure is very simple
2xDirectories in the sever for Stable CT and Lab CT
--www.pilotlogic.com/codetyphon/current/
--www.pilotlogic.com/codetyphon/development/
1 index file in these directories
--www.pilotlogic.com/codetyphon/current/zzctdirver.ctv
--www.pilotlogic.com/codetyphon/development/zzctdirver.ctv
now go to local CodeTyphon C:\codetyphon\allzips directory and you will see all sub directories and files
C:\codetyphon\allzips\binBase.7z = www.pilotlogic.com/codetyphon/current/binBase.7z or
C:\codetyphon\allzips\binBase.7z = www.pilotlogic.com/codetyphon/development/binBase.7z
C:\codetyphon\allzips\src\typhon_src.7z = www.pilotlogic.com/codetyphon/current/src/typhon_src.7z or
C:\codetyphon\allzips\src\typhon_src.7z = www.pilotlogic.com/codetyphon/development/src/typhon_src.7z
My suggestion is to use CTCenter to update CT
some times if our first Server is overloaded, we redirect these web directories to our second web server
or to any server we want
The following user(s) said Thank You: Johan
How does CTC connect to server 11 years 5 months ago #7292
  • Johan
thanks for the info, but what connection protocol is CTC update using, same same settings as IE explorer or does the center has his own connection settings to define proxy etc...
regards,
Johan
How does CTC connect to server 11 years 5 months ago #7293
CT use wget Sir
(for CT user security reasons, only http)
You can read wget manual C:\codetyphon\help\pdf\gnu_wget.pdf OR
from here
OR
read this topic
How does CTC connect to server [SOLVED] 11 years 5 months ago #7364
  • Johan
Ok all is working now.
