Include in CT 12 years 10 months ago #4704
  • avra
  • avra's Avatar Topic Author
OMultiPanel is a TSplitter replacement that allows you to split windows percentually:
www.kluug.net/omultipanel.php
Kluug has made this fast XML parser compatible with Lazarus:
www.kluug.net/omnixml.php
Please include them if they fit in CT vision. They also work in Delphi so most people maintaining old projects will prefer these over other possibilities.
Include in CT 12 years 10 months ago #4705
we will do
The following user(s) said Thank You: avra
Include in CT 12 years 10 months ago #4706
  • avra
Thank you very much!
Here is my little contribution for kOmniXML. I have converted 7 demos to Lazarus, but for 2 demos (BioLife and Storage) conversion was not a success because I didn't have Delphi near by. If someone converts them too then please let me know here. I have also added one additional demonstration example in Avra directory. You can include all these into CT if you wish with kOmniXML original license.
Have fun,
Avra
File Name: Avraconver...zarus.7z
File Size:231 KB
Include in CT 12 years 10 months ago #4707
Include in CT 12 years 10 months ago #4712
  • 4aiman's Avatar
I believe that CT had syntax highlighters for lua, asm and other anguages to use them with synedit.
But in my CT 4.5 I can't find any of additional highlighters... Where did those go?
Include in CT 12 years 10 months ago #4750
  • avra
Maybe these Rack controls converted from Delphi might be interesting to someone? I have checked the original license and the code seams to be in public domain.
ventoso.org/luca/rackctls/
Include in CT 12 years 9 months ago #4786
  • 4aiman's Avatar
And I've thought that highliters addition proposal was noticed... Silly me :)
I really thing there'a a lot to fix in the currently available components and core features as well as porting related packages, like additional highliters or indy components.
Warning: Spoiler!
Include in CT 12 years 9 months ago #4926
We will add to next CT ver 4.7
OXml library not OmniXML
More info Here
source code SVN
Status: Win32, Win64 OK
Now We try to convert OmniXML samples to OXml
Include in CT 11 years 4 months ago #7232
  • avra
OXml has commercial license and CPAL-1.0 license, and not any of the licenses mentioned in c:\codetyphon\typhon\components\pl_OXml\license.
According to site www.gnu.org/philosophy/license-list.html CPL means:
This is a free software license. It is based on the Mozilla Public License version 1, and is incompatible with the GPL for the same reasons: it has several requirements for modified versions that do not exist in the GPL. It also requires you to publish the source of the program if you allow others to use it.
and from the site of original author:
1.) Can I use OXml in commercial applications without purchasing a commercial license?
Yes, you can. But as stated in CPAL, you have to display the Original Developer's Attribution Information each time an Executable or Source Code or a Larger Work is launched or initially run (which includes initiating a session). You can find the text of the required attribution text in the file "license.CPAL 1.0.html" in EXHIBIT B. If this is not an alternative for you, you can purchase a full commercial license from www.kluug.net that allows you to use OXml without any attribution.
2.) Can I use OXml in freeware applications without purchasing a commercial license?
Yes, you can. But you have to attribute OXml in the same way as described in 1.).
Therefore I still vote for OmniXML to be included in CodeTyphon. It has much more liberal MPL 1.1 license.
Last edit: by avra.
Include in CT 11 years 4 months ago #7234
the SVN copy of OXml we have in our lab, has this license.txt with date 13-12-2013
OXml License
Author, initial developer of the OXml library:
  Ondrej Pokorny
  http://www.kluug.net
  All rights reserved.
The contents of all files in the library are subject to the:
  1.) Mozilla Public License Version 1.1 (MPL 1.1)
    -> see "license.MPL 1.1.txt" for full license text.
  OR
  2.) GNU General Public License version 2.0 (GPLv2)
    -> see "license.GPLv2.txt" for full license text.
  OR
  3.) GNU Library or Lesser General Public License version 2.0 (LGPLv2)
    -> see "license.LGPLv2.0.txt" for full license text.
  OR
  4.) FPC modified GNU Library or Lesser General Public License (FPCmodifiedLGPLv2)
    -> see "license.FPCmodifiedLGPLv2.txt" for full license text.
You may not use any of the files from OXml library except in compliance
with one of the Licenses "MPL 1.1", "GPLv2", "LGPLv2" or "FPCmodifiedLGPLv2".
then new SVN copy of OXml license.txt sourceforge.net/p/oxml/code/HEAD/tree/trunk/license.txt
with date 10-07-2014
OXml License information
  Ondrej Pokorny
  1.) Common Public Attribution License Version 1.0 (CPAL-1.0)
    -> see "OXml license CPAL 1.0.html" for full license text.
  OR
  2.) OXml commercial license (if you purchased OXml from Kluug.net).
    -> see "OXml commercial license.txt" for full license text.
  There is an exception: the demos (in "demos/" directory) are public domain
  (if not stated differently).
  1.) in compliance with the "CPAL 1.0" License
  OR
  2.) if you purchased OXml, in compliance with the "OXml commercial license".
License FAQ:
  Yes, you can. But as stated in CPAL, you have to display the Original Developer�s
  "OXml license CPAL 1.0.html" in EXHIBIT B.
  from http://www.kluug.net that allows you to use OXml without any attribution.
3.) If I buy an OXml license, how long is the commercial license valid?
  The commercial license is perpetual for OXml source code that has been released
  within a year after your purchase.
  If you want to update to OXml source code that has been released after 1 year
  of your purchase, you have to obtain a new license (with a 60% discount).
So, the Author of OXml have change the License of this library
The new OXml Library license is OUT of CodeTyphon Licenses Scope
so, we will Remove OXml Library from next CT version
Include in CT 11 years 1 month ago #7828
  • skrzat
  • skrzat's Avatar
I have used pl_oxml in my project. I upgraded CT to 5.4 and noticed during compilation that there is no this package. I should be a note in changelog (about removing). Lastly I found this post.
What can I use instead of pl_oxml?
Include in CT 11 years 1 month ago #7830
we remove pl_oxml for License reasons
you can download and use oxml from here
