Suggestion: Integrated KZDesktop into CodeTyphon 14 years 1 month ago #2411
  • Tom
  • Tom's Avatar Topic Author
Description
The KZDesktop is a package for Lazarus that, when activated, turns the lazarus IDE to an IDE alternative, similar to Microsoft Visual Studio IDE.
Very active development this days.
sourceforge.net/projects/kzdesktop/
Suggestion: Integrated KZDesktop into CodeTyphon 14 years 1 month ago #2412
we plan something like this
we have the first code approach, but has problems on Linux/FreeBSD
Lab guys are on holidays now...
we will see
Suggestion: Integrated KZDesktop into CodeTyphon 14 years 1 month ago #2426
  • 4aiman's Avatar
Maybe there's no need to include all code from kzdeskop then, but just that part with form designer docking? That way anyone would be able to switch to/from this MSVS-like appearance without installing/uninstalling kzdesktop package *scratch*
Suggestion: Integrated KZDesktop into CodeTyphon 14 years 1 month ago #2429
Soon we will release
some screens, but we has problem with Linux OS
Suggestion: Integrated KZDesktop into CodeTyphon 14 years 2 weeks ago #2535
  • tony
  • tony's Avatar
I would like to see this as well.
Why not just use the KZDesktop code instead of duplicating effort?
Suggestion: Integrated KZDesktop into CodeTyphon 14 years 2 weeks ago #2536
We working to make IDE more productive,
but with our way...
Suggestion: Integrated KZDesktop into CodeTyphon 13 years 6 months ago #3534
  • HNB
  • HNB's Avatar
Any progress with KZDesktop? Anchor Docking sometimes crash the IDE...
Last edit: by HNB.
Suggestion: Integrated KZDesktop into CodeTyphon 13 years 6 months ago #3535
No Sir
we will stay with pl_GlassDocking
Suggestion: Integrated KZDesktop into CodeTyphon 13 years 6 months ago #3596
  • a.atalla
  • a.atalla's Avatar
yea it has this issue in linux
Last edit: by a.atalla.
Suggestion: Integrated KZDesktop into CodeTyphon 13 years 4 months ago #4026
  • tony
  • tony's Avatar
sternas wrote: Thanks Sir
we will see
Any new info on this? Would love to see docked forms support like in Delphi.
Suggestion: Integrated KZDesktop into CodeTyphon 13 years 4 months ago #4028
KZDesktop use "visualization" for design forms on Unix systems
so we adapt the idea (for the moment)
Delphi is a Native Windows32 IDE. Unix has not the same API.
Our vision is NOT to clone Delphi IDE...
and Delphi is far behind CT as Pascal Programming Studio
The following user(s) said Thank You: Bobi
Suggestion: Integrated KZDesktop into CodeTyphon 13 years 4 months ago #4035
  • HNB
  • HNB's Avatar
Not all of the ideas from Delphi are bad. IMO Integrated designer and advanced project inspector is a good thing. :side:
Suggestion: Integrated KZDesktop into CodeTyphon 12 years 4 months ago #5545
  • user01
  • user01's Avatar
Integrated Form Designer would be very handy. Not just because it's Delphi-like or VS-like, but just because it's really very handy.
Can it also have an ability to save tabbed panels?
