× General Forum discussions that don't fit in any of the other specific forum categories, help etc.
Question Code Typhon and Android.
  • fredvs
  • Junior Boarder
  • Junior Boarder
2 weeks 5 days ago #11374 by fredvs
fredvs created the topic: Code Typhon and Android.
First of all, a big WOW for the CT toolchain Linux intel 64 ---> Android arm 32.
It works perfectly.
I did use it for create a Java native library (libuos.so) that works, out of the box, on a Android machine.
The library is used by a Java class.
But there is something that disturb me...
What can you do with a application compiled for Android (not a Java native library), because Android cannot deal with "classical" executable ?
Thanks for answer.
2 weeks 5 days ago #11375 by Sternas Stefanos
Sternas Stefanos replied the topic: Code Typhon and Android.
My friend
look here
and here
Android NDK has BIG problems...
  • fredvs
  • Junior Boarder
  • Junior Boarder
2 weeks 5 days ago - 2 weeks 5 days ago #11378 by fredvs
fredvs replied the topic: Code Typhon and Android.
Huh, I did install first Android studio.
It install SDK out of the box, then manually install NDK without problems.
For cross-compiling C libraries, I use a custom shell (see attachment) and it cross compile ok.
For Pascal libraries ---> CodeTyphon toolchain --> OK
Then, with Android Studio, I create a pkg with a Java class that use the libraries.
And both C and Pascal libraries work perfectly on the Android machine.
So the question was:
OK to cross compile for Android a library (that can be used by a java class) but what to do with a program, could it be used by Android ?
IMO Android is a Java OS (that can not deal with "classical".ELF executable.
Last Edit: 2 weeks 5 days ago by fredvs.
2 weeks 5 days ago - 2 weeks 5 days ago #11380 by Sternas Stefanos
and now comes the "Dual personality" of Android
-For Low level System Libraries you can use Pascal or C/C++ ( targeting to Android NDK API)
-For Android GUI Application (native java)
--- you must use Java or FPC pas2jni info
OR
--- to make your own GUI API like CT customdrawn platform
But FreePascal Team is working on pas2js pascal to JavaScript
and I think the improve of pas2jni is the next FPC target
LAB CT 6.4 on Win64 now..
Last Edit: 2 weeks 5 days ago by Sternas Stefanos.
  • fredvs
  • Junior Boarder
  • Junior Boarder
2 weeks 4 days ago #11382 by fredvs
Hello Sternas.
Ha, ok, so, if understand ok, cross-compiling to Android will work only for native Java libraries.
And cross-compiling applications will work only with complicated translation into a Java class or Java script.
IMO, I am not fan of this, I prefer use the Java widget-set directly.
And for the complicate code, I do create a Pascal Java native library and use it by the main Java class.
Thanks for explanation Sternas.
2 weeks 4 days ago #11385 by Sternas Stefanos
Have fun my friend
  • fredvs
  • Junior Boarder
  • Junior Boarder
6 days 20 hours ago - 6 days 20 hours ago #11409 by fredvs
Hello Sternas.
Sorry but, once again, I have a (difficult to explain) question... :blush:
If you have a C native library (for example PortAudio, Mpg123 or SndFile) and if you want to cross-compile from Linux to Android, the C
cross-compile chain add automaticaly the 2 first parameters needed for a native Android library (and Java too of course).
For example, this native method (translated in Pascal):
function mynativemethod(paramnative : integer): integer; cdecl;
will be transformed by the C cross-compiler into:
function mynativejavamethod(PEnv: PJNIEnv; Obj: JObject ; paramnative : integer): integer; cdecl;
// 2 first parameters were added
But how does the CT cross-compiler?
Does it add automatic also the 2 first parameters (PEnv: PJNIEnv and Obj: JObject) or must it done by the programmer ?
When I did use CT cross-compiler, I did add those 2 first parameters to each exported method of the Pascal library and the result is a Java native working Android library.
But now I have some doubt, maybe those parameters were also added by the CT toolchain (or by the NDK)?
Do you know if it exist a way to know the parameters needed in a exported method of a library?
Huh, I hope you did understand something...
Last Edit: 6 days 20 hours ago by fredvs.
  • fredvs
  • Junior Boarder
  • Junior Boarder
1 day 21 hours ago - 1 day 21 hours ago #11438 by fredvs
I note this here in case somebody needs it (or if I forget it ;) ).
When you have downloaded and compiled the Android tool-chain and have downloaded the Android Oses libraries you may have this error messages at compiling:
/usr/local/codetyphon/fpc/fpc64/bin/x86_64-linux/arm-linux-androideabi-ld.bfd: cannot find -llog
/usr/local/codetyphon/fpc/fpc64/bin/x86_64-linux/arm-linux-androideabi-ld.bfd: cannot find -ldl
/usr/local/codetyphon/fpc/fpc64/bin/x86_64-linux/arm-linux-androideabi-ld.bfd: cannot find -lc
uoslib.pas(511,93) Error: Error while linking
It is because the search path for those libraries was not defined.
Just add this in your fpc.cfg (according with the api you want):
(or add this parameter at compilation)
#ifdef cpuarm
-Fu/usr/local/codetyphon/binLibraries/android-4.0-api14-arm
#endif
Suggestion: Maybe CT could add this in the cross-compile chain-script.
Last Edit: 1 day 21 hours ago by fredvs.
1 day 14 hours ago - 1 day 14 hours ago #11441 by Sternas Stefanos
Just
add your Android libraries path to your project "Libraries"
like this
In CT you don't need to edit fpc.cfg for any programming action.
Last Edit: 1 day 14 hours ago by Sternas Stefanos.
