Visual Planit - I created an example 12 years 4 months ago #5279
  • Francesco Sammarco
  • Francesco Sammarco's Avatar Topic Author
Finally after a while I downloaded codetyphon and I took the package of visual planit. I created the database (firebird - agenda.fdb) found that in the sample project. The SQL structure was created by going to trial.
It does not work well events management. He shows me only the last event inserted when I restart the program. Can anyone tell me why?!
Here you will find the package to install:
www.lazaruspascal.it/laz_packages/pl_VisualPlanIt.zip
Here is the example to download the db included:
www.lazaruspascal.it/esempi/agenda.zip
Visual Planit - I created an example 12 years 4 months ago #5280
  • universe
  • universe's Avatar
All events are selectable by the resourceid key (is datastore.resource), so you should verify this key after inserting and when reading and you have to call LoadEvents or RefreshEvents method after changing it.
Last edit: by universe.
Visual Planit - I created an example 12 years 4 months ago #5282
I can not seem to use any other value for the field RecordId -1073749720. It then updates the same record. I do not understand why. Even if you change the primary key does not work. It seems to be a bug
Visual Planit - I created an example 12 years 4 months ago #5283
  • universe
  • universe's Avatar
Hello, I'll try to upload a simple working example with Postgres asap.
Edit:
Did you map database fields?
Visual Planit - I created an example 12 years 4 months ago #5288
We have mapped the data. I would be very grateful if you put the example :)
So I look forward
Visual Planit - I created an example 12 years 4 months ago #5289
  • universe
  • universe's Avatar
I'll do my best to prepare it in the next weekend, but I just want to inform you that the mapped fields should have exactly the same names as defined in the datatstore fields, changing the names will create a non-common behavior (certainly a bug) for some methods call even after a correct mapping.
Visual Planit - I created an example 12 years 4 months ago #5293
There's just a different field because that name is private into firebird.
Visual Planit - I created an example 12 years 4 months ago #5303
  • universe
  • universe's Avatar
That could be the root cause of the failure, if you have another database server on your computer (mysql, postgres) try your code on it.
Visual Planit - I created an example 12 years 4 months ago #5304
I'll try. Meanwhile, You can create me that example?!
Visual Planit - I created an example 12 years 4 months ago #5305
  • universe
  • universe's Avatar
Yes
The following user(s) said Thank You: Francesco Sammarco
Visual Planit - I created an example 12 years 4 months ago #5306
  • universe
  • universe's Avatar
Well, this is a simple example , just create the database with the tables in creates.txt and then launch the application and connect, it will load a default resource named "PlanThis" then you could right click on the WeekView and plan events. Hope this helps. (tested on Postgres 8 and 9)
Visual Planit - I created an example 11 years 9 months ago #6080
  • Maximiliano
  • Maximiliano's Avatar
I'm test this, but run to slow. is normal?
CT5.1 lab
