Use components UniDAC see 4.6.12 14 13 years 1 month ago #3774
  • Avaro Nates
  • Avaro Nates's Avatar Topic Author
I am migrating my application made ​​in delphi using codetyphon, I used version 4.6.12 UniDAC components 14, and I could not install in codetyphon, any help will be very important for me, thanks.
Use components UniDAC see 4.6.12 14 13 years 1 month ago #3775
  • Thank you received: 1132
UniDAC is commercial Library
We don't have the source, to help you.
Please, ask for help from UniDAC Develop Team
Use components UniDAC see 4.6.12 14 13 years 1 month ago #3776
  • Avaro Nates
well, they give there support for lazarus installed fine, but
codetyphon definitely want to work on.
Use components UniDAC see 4.6.12 14 13 years 1 month ago #3789
  • Adriano Soares
  • Adriano Soares's Avatar
I am also using UNIDAC 4.6.12 14.
I had to make small modifications on the source of component, but it is working very well.
regards
The following user(s) said Thank You: Angelo Mangiaracina
Use components UniDAC see 4.6.12 14 13 years 1 month ago #3798
  • Avaro Nates
almsoares, kindly help'd be able to use these components in codetyphon?. my email is 'This email address is being protected from spambots. You need JavaScript enabled to view it.' thanks
Use components UniDAC see 4.6.12 14 4 years 3 weeks ago #17035
  • Brues
  • Brues's Avatar
Can you share your modified component package Or the latest version?
Use components UniDAC see 4.6.12 14 2 years 11 months ago #17821
  • Angelo Mangiaracina
  • Angelo Mangiaracina's Avatar
Can you share your changes with us? I need to use it also.
Thankyou
