× Tools, Toolchains, OS Scripts, OS Libraries, discussions, problems and suggestions
Question how to change default to D and how to change language
  • Mark
  • Mark's Avatar Topic Author
  • Fresh Boarder
  • Fresh Boarder
1 year 2 months ago #10472 by Mark
Mark created the topic: how to change default to D and how to change language
Hi
All installed well, but my C disk is very small so i would like to use d: as a default. I changed all bat & sh file but the code also points to c:\typhon
Is there some setting or easy way to change this?
Second, i see that part of the IDE is in english and dutch. I would like everything in English. Is there some setting i can set to force the language?
thanks !
1 year 2 months ago - 1 year 2 months ago #10473 by Matis A.
Matis A. replied the topic: how to change default to D and how to change language
1) No, CT must installed to C:\codetyphon on Windows OS
2) Try, Typhon>>Tools>>Options>>General (tab) and select only English [en]
CodeTyphon Core Programmer
Last Edit: 1 year 2 months ago by Matis A..
The following user(s) said Thank You: Mark
  • Mark
  • Fresh Boarder
  • Fresh Boarder
1 year 2 months ago #10474 by Mark
Mark replied the topic: how to change default to D and how to change language
thank you for your help. The EN forced setting works :-)
