CT LAB ver 5.10 12 years 1 month ago #6002
  • Online
28-9-2014 Revision: 005011 LAB Actions
--10-9-2014 Update to FPC SVN Rev 28636
--10-9-2014 Synchronize with Lazarus SVN Rev 46167
--11-9-2014 New Build FPC procedure for Windows, same as Unix with use of newfpc directory
--11-9-2014 New FPC Directory Structure:
old codetyphon\fpc\bin
new codetyphon\fpc\fpc32\bin
or  codetyphon\fpc\fpc64\bin
for better MultiArch ability support
--11-9-2014 Update and Fix all Scripts
--12-9-2014 Update and Fix all Crossbuild Scripts
--13-9-2014 Start Lab Task: Update and Fix Problems of "Embedded Form Designer"
--13-9-2014 Typhon IDE Fix some Toggle Form to Unit problems
--14-9-2014 Update to FPC SVN Rev 28653
--16-9-2014 Fix CTCenter Upx Tool for Unix OSes
--16-9-2014 Fix CTCenter FpcMake Tool for Unix OSes
--16-9-2014 Fix CTCenter TyphonBuild for Unix OSes
--16-9-2014 Fix CTCenter Strip Tool
--16-9-2014 Synchronize with Lazarus SVN Rev 46245
--25-9-2014 Update pl_Indy to SVN Rev 5189 and fix WinCE Problems
--25-9-2014 Update pl_BGRAbitmap to SVN Rev 927 ver 7.8
--25-9-2014 Update pl_BGRAControls to SVN Rev 43
--27-9-2014 Add to IDE Options->Desktop the selection "Send Msg to Message Windows"
--27-9-2014 Finish Lab Task: Update and Fix Problems of "Embedded Form Designer"
09-10-2014 Revision: 005021 LAB Actions
--06-10-2014 Update pl_ECControls to Ver 0.9.1.12 and CodeOcean Samples
--07-10-2014 Update FPC to SVN Rev 28783
--07-10-2014 Update pl_GlassDocking to Ver 2.5.1 (Fix "Pages" problems after 1 year... )
--07-10-2014 Update CTCenter, now has "Two-Way communication" with the execute Action, so now we can write OS-Scripts with Questions and Selections for the user.
--08-10-2014 Fix assembler dialog problems
--08-10-2014 Fix pl_GlassDocking "Empty Forms" problem, after minimize and restore Typhon IDE
--09-10-2014 Update FPC to SVN Rev 28790
--09-10-2014 Synchronize with Lazarus SVN Rev 46488
--09-10-2014 Fix some CustomDraw Platform problems on Win64
Note1: You can download and test this version from "CTCenter->Update Manager" and select CT Development Version
Note2: Please post to this topic any suggestion or problem or fix for LAB CT ver 5.10
The following user(s) said Thank You: gulyone
CT LAB ver 5.10 12 years 1 month ago #6003
  • zbyna
  • zbyna's Avatar
Great :)
CT LAB ver 5.10 12 years 1 month ago #6004
  • David
  • David's Avatar
Thanks Sr.
trying , but in update manager, only show 5.0, and don't allow download.
Last edit: by David.
CT LAB ver 5.10 12 years 1 month ago #6005
  • Online
No Release yet Sir
But we prepare the new Lab version
Until Now the most Critical:
1) -New FPC Directory Structure
old
codetyphon\fpc\bin
new
codetyphon\fpc\fpc32\bin or
for better CrossBuild support in MultiArch Installations
2)- Many Fixes to Embedded Form Designer
3)- Two Edit Modes to Embedded Form Designer: "AlwaysTopLeft" and "ScreenNature"
The following user(s) said Thank You: Miquel Matas, FredyCC
CT LAB ver 5.10 12 years 1 month ago #6023
  • Online
28-9-2014: We release Lab CT 5.10 Revision: 005011
please test and report here
CT LAB ver 5.10 12 years 1 month ago #6024
  • Vbxler
  • Vbxler's Avatar
Problems viewing of large forms.
CT LAB ver 5.10 12 years 1 month ago #6025
  • Online
On first pic just scroll to the right the bottom horizonal Scroll
on second pic just move (click and hold in Review panel on bottom-Right cornel) the form in the screen
CT LAB ver 5.10 12 years 1 month ago #6026
  • Vbxler
  • Vbxler's Avatar
Thank you Sir, I did not see the scrollbar.
CT LAB ver 5.10 12 years 1 month ago #6027
  • Maximiliano
  • Maximiliano's Avatar
Run fine, fixed my bad installation on CT 5.00.
Ffixed division by zero.
Good job Sir Sternas.
CT LAB ver 5.10 12 years 1 month ago #6028
  • Online
We test it for 10 days on Win, Linux, FreeBSD and Solaris
GTK2, QT and Win API
Our next Lab task is to Fix Page Docking problems of pl_GlassDocking
and support for OpenBSD
CT LAB ver 5.10 12 years 1 month ago #6029
  • David
  • David's Avatar
Hi Sr.
Testing CT 5.10 croscompile on Win8 64bits to cubieboard , ( CT WIN32 and CT WIN64 )
1 - Installed CT 5.0 in a new virtualbox machine.
1 - Updated to CT 5.10 (remove and build all)
2 - Downloaded cubiuntu libs
3 - Downloaded toolchain win32-arm-linux-cubieboard and toolchain win64-arm-linux-cubieboard
4 - fpc32 , build cross element arm-linux--cubieboard , but some errors when compiling
make[1]: Leaving directory `c:/codetyphon/fpcsrc/installer'
C:/codetyphon/fpc/fpc32/bin/i386-win32/rm.exe -f build-stamp.*
C:/codetyphon/fpc/fpc32/bin/i386-win32/rm.exe -f base.build-stamp.*
Could not find C: \ codetyphon \ fpcsrc \ compiler \ utils \ * exe.
Could not find c: \ codetyphon \ fpcsrc \ utils \ * exe.
        Stage 5: Copy Files and Units
Subdirectory or file already exists .. \ .. \ fpc \ fpc32.
File not found. *
0 file (s) copied (s)
  [ERROR]: win32 Cross Element for arm-linux Param: Cubieboard NOT Exists
         sorry, build STOP
Terminate Action at 29/09/2014 22:44:11
Total time: 00: 03: 22.937
ExitCode: 0
5 - fpc64 , build cross element arm-linux--cubieboard , but same errors when compiling
6 - Created a simple Project, add cubiuntu libs, target OS: Linux, Target CPU : arm , Target Procesor : ARMV7 and ARMV7M, try to compile but fail,
Hint: (11030) Start of reading config file C:\codetyphon\fpc\fpc32\bin\i386-win32\fpc.cfg
Hint: (11031) End of reading config file C:\codetyphon\fpc\fpc32\bin\i386-win32\fpc.cfg
Free Pascal Compiler version 2.7.1 [2014/09/29] for arm
(1002) Target OS: Linux for ARMHF
(3104) Compiling fcllaz.pas
Error: C:\codetyphon\fpc\fpc32\bin\i386-win32\ppcrossarm.exe returned an error exitcode
I attach the fpc32 and fpc64 cross element detail, errors at the end.
CT LAB ver 5.10 12 years 1 month ago #6030
  • Online
On Second file
C:/codetyphon/fpc/newfpc/units/arm-linux/rtl, ...) failed.
make (e=740): La operación solicitada requiere elevación.
make[1]: *** [fpc_install] Error 740
make[1]: Leaving directory `C:/codetyphon/fpcsrc/rtl'
make: *** [rtl_install] Error 2
To fix make error 740 on Win8 read here
on Win 7 64 bits All OK
the same on FreeBSD 64 10.x and Linux 64 (Fedora 20 with MultiArch CodeTyphon Installation)
PS: We prepare a test of CT on Win 9 soon... :)
The following user(s) said Thank You: David
CT LAB ver 5.10 12 years 1 month ago #6031
  • David
  • David's Avatar
Thanks Sr.
Finally after some errors, I managed to compile some projects
There are missing libs in www.pilotlogic.com/codetyphon/libraries//arm-linux-Cubiuntu.7z (like opengl libs), but using all my libs ( drive.google.com/file/d/0Bw7tdxYw_to3TlN...dTA/edit?usp=sharing ) , seems that all projects compiled fine
I will do more test and report it in cubieboard section.
CT LAB ver 5.10 - Ctrl-Space problem 12 years 1 month ago #6033
  • Dinko
  • Dinko's Avatar
  • Thank you received: 5
I just installed 5.10 mainly because of problem with debugger.
Installed via update on Win7-64. I use Typhon32 version
Now, I can not say anything about debugger, but when I press Ctrl-Space, editor always go to IdGlobal.pas and position to line 78 in which
it is written {$I IdVers.inc} . Error message is always Include File Not Found IdVers.inc.
I checked Indy package search path and it is OK: source;source\base.
Can you help me about this problem because I use a lot ctrl-space for code completion and it seems it is practically impossible to use it right now.
Regards, Dinko
CT LAB ver 5.10 - Ctrl-Space problem 12 years 1 month ago #6034
  • Dinko
  • Dinko's Avatar
I forgot to wrote. This is only true for units that have IdGlobal in uses list.
My uses include
IdHTTPServer, IdSocketHandle,
IdCustomHTTPServer, IdContext,
IdGlobal,
IdGlobalProtocols,
IdHTTP
Regards, Dinko
CT LAB ver 5.10 12 years 1 month ago #6035
  • Online
tefots wrote: Thanks Sr.
excellent news :woohoo:
we must update arm-linux-Cubiuntu.7z library,
and we want your help
PS: Yes report to cubieboard section
CT LAB ver 5.10 - Ctrl-Space problem 12 years 1 month ago #6036
  • Online
dinmil wrote: I just installed 5.10 mainly because of problem with debugger.
Regards, Dinko
Sir, just ADD to pl_Indy pkg the IdVers.inc file
or download the updated pl_Indy pkg from here
CT LAB ver 5.10 - Ctrl-Space problem 12 years 1 month ago #6042
  • XANDR
  • XANDR's Avatar
mr. Sternas, are planned the arm-qt-linux support for 5.10 or 5.XX version? Or this not planned now at all?
CT LAB ver 5.10 - Ctrl-Space problem 12 years 1 month ago #6044
  • Online
CT 5.10 has FULL QT support for arm-linux.
The missing part is the qt4pas libraries (libQt4Pas.so.5.2.5 etc) on
arm-linux-Cubiuntu.7z OS-library and arm-linux-Raspbian.7z OS-library
We will update arm-linux-Cubiuntu.7z OS-library with all QT (KDE Desktop) missing files before CT 5.10 release
PS: In C:\codetyphon\allzips\binqt forder you can find
libQt4Pas.so.5.2.5 for arm-linux ( armv7hl) from Fedora 2014-05-15
CT LAB ver 5.10 - Ctrl-Space problem 12 years 1 month ago #6048
  • XANDR
  • XANDR's Avatar
Thanks!, I will try test this soon...
