Cross build for Android failed with CodeTyphon 6.40 8 years 5 months ago #11536
  • rarnu
  • rarnu's Avatar Topic Author
Sir, I have CodeTyphon 6.40 installed with cross element lin64-arm-android.
when I try to build a library for android, I got the error:
/usr/local/codetyphon/fpc64/bin/x86_64-linux/arm-android-ld: error: link.res:169:8: syntax error, unexpected STRING
/usr/local/codetyphon/fpc64/bin/x86_64-linux/arm-android-ld: fatal error: unable to parse script file link.res
My project and build script are attached. Please help.
And, if I build it with CodeTyphon 6.00, it works fine.
Cross build for Android failed with CodeTyphon 6.40 8 years 4 months ago #11554
we test your project with Lab CT 6.50
- on Linux 64, Debian 9.4 and
- on Windows 64 10 Ent
1) On Linux64, with Typhon32 and Typhon64 we get the same ERROR (screen 1)
2) On Windows64, with Typhon32 all are OK (screen 2)
3) We attach your modified project from our Windows tests
Now, we will test again linux arm-android tool-chains
but all OSes are NOT the same.
My suggestion for native android Crossbuild is to use Windows OS
have fun...:)
