Re: Install problems 15 years 2 weeks ago #1368
  • tkamphuis
  • tkamphuis's Avatar Topic Author
Installing the new version 2.30 is very easy. No problems any more.
Re: Install problems 15 years 2 weeks ago #1369
Thanks Sir, for your report
We want more users report/suggestions
Re: Install problems 15 years 2 weeks ago #1370
  • 4aiman's Avatar
ubuntu 10.10.
Build Big Ide - ok!
but then...
I've removed all fpc and lazarus before installation. I Did install system libraries.
And I've fount some fpc.cfg in /etc.
Where I'm supposed to put it to?
regards!
Last edit: by 4aiman.
Re: Install problems 15 years 2 weeks ago #1371
Method1
Please go to your /etc/ directory end delete fpc.cfg is from Old Freepascal installation
copy CodeTyphon fpc.cfg to your /etc (/user/lib/codetyphon/bin/binfpc/i386-linux
and give to you (username) Linux permissions to read this new file /etc/fpc.cfg
sudo rm -f /etc/fpc.cfg
sudo cp -f /user/lib/codetyphon/bin/binfpc/i386-linux/fpc.cfg /etc/
sudo chmod 644 /etc/fpc.cfg
But this is automatic procedure from CodeTyphon ...so
Method2
try to remove /etc/fpc.cfg ( sudo rm -f /etc/fpc.cfg )
and run from CTC "remove and build ALL"
Re: Install problems 15 years 2 weeks ago #1372
  • Rain
  • Rain's Avatar
CT 2.30 installs flawlessy on Win XP.
Only the file associations are not adjusted to the new locations.
.lpr, .lpi, .pas, .pp point to the old locations. This can be corrected manually, so it's no problem.
Also Remove and Build ALL does not remove CT 2.20 installations c:\lazarus and c:\pp remain untouched. It just adds the c:\codetyphon directory with content.
But this doesn't affect functionality.
The new CT 2.30 runs fine.
Re: Install problems 15 years 2 weeks ago #1373
  • 4aiman's Avatar
rain wrote: Also Remove and Build ALL does not remove CT 2.20 installations...
It never did. Every time you should either cleanup using old CTC or remove old files manually.
Haven't you read some other messages about installation problems? Every time sternas asks whether you run cleanup or not. Even if new CT removes smth that belong to old one - no one ever said it should.
And on top of that, sometimes uninstalling old CT with new CTC ends in loss of opportunity to install ANY version of CT. If someone want deny this - just install CT 1.6 (yes, even now I'm using ver 1.6 CT, as it proved itself as stable one, where glscene runs fine, and there's no some errors like "it need to be implemented" although 1.6 already did the same thing, and so on and so forth) and then use "remove and build all" option from CT 2.2 installator or CTC menu. After this xp sp3 pro cannot build neither big nor small ide. And cleanup "by hands" is a long and confusing procedure.
Let sternas correct me if I'm wrong, but I've some code samples which compiles in 1.6. and refuse to compile in any of the later CT. And I've wrote it here, but got no response. And tomorrow I'll try to change old fpc.cfg with new one (although i Did cleanup, and just can't understand why there's old file, and why it's not overwritten automatically during installation if it shares the same place with old one...)
If anyone interested in my samples that lead lazarus to crash - tell me, cause just posting isn't enough, but i'm afraid my samples will be ignored as some of my messages... and... well, it's not about CT, but any attachment is GONE after submitting a post.
I'm not trying to MAKE someone to do smth, I just want to help, as I really want new, better version of what I'm already have... But, please, if you has smth important to do (like new ct 2.3) let us all know, that our problems are intended to be solved soon, as new ver is comming out soon... Else it's makes me (personally) feel like there's no point in feedback, as there's no reaction.
Regards!
Re: Install problems 15 years 2 weeks ago #1374
CT version 2.30 is the best until now
and GLScene run ok to all CT Host Layers
We make the new CT 2.30 directory structure:
-for better installation
-to solve makefiles problems
-to prepare CT for next Generation Plan with Rolling installation...
etc
CT is dynamic project and we try to make it better.
For sample, at lab version
1)We add to pl_win_directx pkg, support for DirectX 10/11 and
this action request some CT code changes...
2)And the new (experimental) pl_Lava pkg request some CT code changes...
Please Sir,
my suggestion is to remove old installation files (I can post a script file after your request)
and try to install new CT ver 2.30
oh, a screen from pl_Lava pkg on Debian Linux 6.0.3 64 bit...
Re: Install problems 15 years 2 weeks ago #1376
  • 4aiman's Avatar
Here's what I've done:
- run ctc 1.6
- "IDE settings clear"
- "remove lazarus from disk"
- "clean lazarus"
- "remove FPC from disk"
- "clean FPC"
- check for any remaining folders on disc C. None was found (there was no "pp", "lazarus", "lazarus temp", "codetyphon")
Warning: Spoiler!
- unzip to C: ct v2.3
- run ct 2.3
- "FPC extract source"
- "FPC 32bit build compiler"
- "lazarus extract source"
- "lazarus 32bit build big ide"
And here's what I've got: 4aiman.ucoz.ru/warehouse/log.7z
And as for examle I told earlier...
Here is project with some tab controls and glsceneviewer (only 87.6 Kb). When opened under ubuntu 10.10, Lazarus would crash. Could you check that, please?
Re: Install problems 15 years 2 weeks ago #1377
  • 4aiman's Avatar
sternas wrote: Method2
Ok, that worked out. May I suggest adding to installation script a couple of lines then? Lines that will certainly remove old fpc.cfg and replace with new one.
Indeed, 2.3 IS the best now ^_^ Thank you very much for it!
But... oh, I really hate that word...
The example I've provided crashing 2.3 under ubuntu 10.10.
If I add glsceneviewer on the blank form lazarus is ok, but when I add some other controls (maybe too much, but that's not the point) lazarus can hold no longer and crashes. If there's some limitations in ubuntu or in lazarus for ubuntu, I think, that for everyone is better to be aknowledged with that fact. I still could create glsceneviewer at run-time, but want to be sure - if this my fault or smth systematical.
Later...
I've deleted glsceneviewer from unit1.lfm and unit1.pas (in the example, that I've posted here) and create new one.
Lazarus didn't crash! :woohoo:
but... project refuses to run. And if I use terminal and launch project from commandline, I get this:
Warning: Spoiler!
Re: Install problems 15 years 2 weeks ago #1380
Sir,
last 6 month we find that Ubuntu not use "default" libraries
and this is the reason for "Libraries" page at CT Center.
We use Debian, as main DEV distribution in our lab now.
We use SVN GLScene (with OpenGL ES WinCE/Android support)
and the DEV team of this library has focus to Windows 32bit. :unsure:
So, we want your help, on that...
Always you can post here your source...
I can make a new forum for GLScene
I will test your sample (Ubuntu 11.10 and fedora 16) and report here...
Re: Install problems 15 years 2 weeks ago #1381
  • 4aiman's Avatar
Ok. I'll do what I can.
New forum is a bit to much.
I could create a new theme and post there' when I'll find smth to make it work.
Thank for reply anyway.
And now for win 32.
I used to use ct 1.6, since glscene there works fine. With your help I managed to install 2.3 under ubuntu. But now you're aware of the situation, and I need to move forward. That's why I still run win32. It's XP, HE, SP3 with latest uppdates (at least critical ones). It's NOT pirated, if it's important (and it maybe in some cases).
And I still can't install 2.3... I removed 1.6 using ctc 1.6, deleted codetyphin dir from C: and try to install new ct 2.3.
And just can't. I tried to run scripts from ScriptsWin dir after unziping them via ctc. And even if I run "FPC_build" and then "build small ide" the second bat says that there's NO fpc directories! O_o
and second script runs firs to install them, but then can't compile anything anyway...
So...
Gen 2 archive's name is "CodeTyphonIns". I unzipped it to C.
Then run install.bat , 0, then 8.
If the system is clean would it install ct2.3? (Referring to this: C:/CodeTyphonIns/installbin/help/index.html it should).
Then my system isn't clean. Then where should I look&delete in addition to "C:\pp", "C:\lazarus", "C:\codetyphon" and "C:\lazarus temp" ?
And... could it be that bloodshed dev c++ and c compiler named "make.exe" is installed?
I mean should I run cmd and type "make" I would get this:
MAKE Version 5.2  Copyright (c) 1987, 1998 Inprise Corp.
Fatal: Unable to open makefile
Re: Install problems 15 years 2 weeks ago #1382
  • Gintas
  • Gintas's Avatar
  • Graphics Designer/Developer
4aiman wrote: And... could it be that bloodshed dev c++ and c compiler named "make.exe" is installed?
Check the PATH variable settings and make sure there is no path added to MinGW32 installation or any
other "make.exe" folder. Right click on My Computer->Select Properties->Advanced tab->Environment Variables.
Basically if you can execute in CMD make command you must be having a path set to this executable.
I was having similar problem with Code::Blocks C++ IDE installed.
Re: Install problems 15 years 2 weeks ago #1384
  • Konstantinos Papadoulas
  • Thank you received: 19
Another one fully satisfied user of CT 2.30.
Not that i ever had problems installing any of the previous CT versions but i really like the scheme of putting it all together in one directory.
I confirm the flawless installation and production on Win 7 x64 and Win 7 x32. Haven't tried with Ubuntu yet b/c something got messed up with the *new*
Unity interface and i tried trying to fix it (maybe switch to Debian?).
I have also updated my app that will associate the various file types with the Lazarus IDE.
The attached GUI.zip is the source code and the RegLazGUI.zip is the binary for windows.
Kostas
The following user(s) said Thank You: Gintas
Re: Install problems 15 years 2 weeks ago #1385
I will test and put your code to next release
Oh, we use Debian
Re: Install problems 15 years 2 weeks ago #1386
Please Sir Sternas, don't thank me.
I wish i had the power to offer more in CT project. We, the users of CT, should thank
you and PilotLogic for such a great great tool!!
By the way, there is a file missing from the source i posted. Sorry for that. I am keeping some include files in
separate folders and in the above GUI.zip i only zipped the files in the project directory.
Sorry for the inconvenience. I will re - post the complete source code shortly.
Kostas
P.S. While writing this message i am installing CT in a Debian 6.0.3 VirtualBox Machine. It seems that the only thing
missing now is the MacOS port. :)
Re: Install problems 15 years 1 week ago #1387
We test the new OpenBSD CT layer now (SVN freePascal has many fixes for this OS)
then we can go for MacOS planet...
Re: Install problems 15 years 1 week ago #1388
Ok. Here is the full source and the binary x32 of the Register Lazarus app.
Enjoy: )
kostas
Re: Install problems 15 years 1 week ago #1389
  • Miquel Matas
  • Miquel Matas's Avatar
  • Thank you received: 10
Thank you so very much!!!
Re: Install problems 15 years 1 week ago #1390
  • 4aiman's Avatar
Hello everybody!
Previously I asked about mingw c++ and was told that it could be the source of problem.
And at home removing c++ compiler path worked out for me. Success!
But at work I don't have bloodshed c++. Neither I have MS Visual C++ IDE.
Then I try to look at every path in "Path" variable and found... drums... Delphi's "Make.exe" (delphi 7)!
I removed "C:\Program files\Boreland\Delphi7\Bin" from the "Path", but that did NOT solve the problem...
I search for make and for link and for other exe, but found none not only in dirs in path, but on entire HDD...
Then I trie to solve it cordinally. I removed all but "%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;" from path and voila - ct2.3 installed! Feel myself like a least lamer :(
Then I put everything back (restore Path as it was) and that didn't brake ct2.3 :)
Maybe it's worth to change Path before installation right from the instal.bat? So no one got struck at installation, just because there's no others compilers or linkers in %path%... no one even ever notice ;)
Still feel like a lamer, though I knew where's environment variables are to be set...
Re: Install problems 15 years 1 week ago #1391
miquelmatas wrote: Thank you so very much!!!
Be well my friend !! :)
You will find a bug though... In the file unit1.pas and in the line 351 you must change
the code
grpArch.Enabled := (bPath32 and bPath64);
to the code
grpArch.Enabled := (bPath32 or bPath64);
kostas.
P.S. I would like to ask Sir Sternas if there is a public repository for user contributions. Instead of uploading
our changes in the forum every time we find a bug to be able to commit our changes to the repository.
