ERROR building lazarus 64 on fedora 15 kde 15 years 4 weeks ago #1334
  • Hector S Ponce
  • Hector S Ponce's Avatar Topic Author
compiler_buildmacro_options.pas(925,47) Warning: Conversion between ordinals and pointers is not portable
/usr/bin/ld: warning: ../link.res contains output sections; did you forget -T?
/usr/bin/ld: cannot find -lGL
/usr/bin/ld: cannot find -lGLU
/usr/bin/ld: cannot find -lXxf86vm
lazarus.pp(192,1) Error: Error while linking
lazarus.pp(192,1) Fatal: There were 1 errors compiling module, stopping
Fatal: Compilation aborted
make[2]: *** [lazarus] Error 1
make[2]: Leaving directory `/usr/lib/lazarus/ide'
make[1]: *** [bigide] Error 2
make[1]: Leaving directory `/usr/lib/lazarus/ide'
make: *** [idebig] Error 2
strip: 'lazarus': No such file
strip: 'lazbuild': No such file
strip: 'startlazarus': No such file
mv: cannot stat `lazarus': No such file or directory
mv: cannot stat `startlazarus': No such file or directory
mv: cannot stat `lazbuild': No such file or directory
[INFO]: make some links...
Re: ERROR building lazarus 64 on fedora 15 kde 15 years 4 weeks ago #1335
Did you install "must have" System Libraries ? info
Re: ERROR building lazarus 64 on fedora 15 kde 15 years 4 weeks ago #1336
  • Hector S Ponce
yes, no errors...
I installed lazarus from rpm package and works fine
Last edit: by Hector S Ponce.
Re: ERROR building lazarus 64 on fedora 15 kde 15 years 4 weeks ago #1337
These Errors are from basic OpenGL libraries
Your Fedora box don't has these OpenGL libraries
CT Small IDE (like official Lazarus) Don't use OpenGL libraries
But CT big IDE request OpenGL Libraries...
My suggestion
remove all and build "CT Small IDE"
or
install OpenGL libraries and build "CT Big IDE"
Re: ERROR building lazarus 64 on fedora 15 kde 15 years 4 weeks ago #1338
  • Hector S Ponce
After installing missing libraries, BigIDE compiled OK
Thanks for CodeTyphon, you have made a great job !
sudo yum install GLC_lib.x86_64 gtkglarea2.x86_64 gtkglext-devel.x86_64 gtkglext-libs.x86_64
[hp@hpi5 ~]$ sudo yum install GLC_lib.x86_64 gtkglarea2.x86_64 gtkglext-devel.x86_64 gtkglext-libs.x86_64
[sudo] password for hp:
Loaded plugins: langpacks, presto, refresh-packagekit
Setting up Install Process
Package GLC_lib-2.0.0-1.fc15.x86_64 already installed and latest version
Package gtkglarea2-2.0.1-2.fc15.x86_64 already installed and latest version
Package gtkglext-devel-1.2.0-14.fc15.x86_64 already installed and latest version
Package gtkglext-libs-1.2.0-14.fc15.x86_64 already installed and latest version
Nothing to do
Re: ERROR building lazarus 64 on fedora 15 kde 15 years 4 weeks ago #1339
