2.60 SIGSEGV 14 years 4 months ago #1869
  • Keith Johnson
  • Keith Johnson's Avatar Topic Author
Ok, the latest 2.60 seems to have some issues.
Building an application for win32 that uses SQLite, and the following command->
DB.GetTableNames(tbl);
Gives the SIGSEGV. 2.50 was fine.
The debugger is reporting Exception in TCollection.DoClear. Looking at 2 copies of collect.inc I have, it appears there has been a few changes here.
Also compiling same application for WINCE, has issues relating to the BGRABitmap stuff.
It stops in perspectivescan2.inc, line 1 -> {$asmmode intel}
I think the problem is most likely perspectivescan.inc there is at line 108 there is a {$IFDEF CPUI386} but the else is also including perspectivescan2.inc that is only INTEL based.
Re: 2.60 SIGSEGV 14 years 4 months ago #1883
  • Keith Johnson
No response ?..
Anyway, a bit of digging and I believe the error is related to ->
bugs.freepascal.org/view.php?id=21771
Re: 2.60 SIGSEGV 14 years 4 months ago #1884
We try to fix and this Sir
Re: 2.60 SIGSEGV 14 years 4 months ago #1920
  • Keith Johnson
Did you have any luck?
A little bit more information for you.
I would get the SIGSEGV just by writing a program that created a TDataset descendant component, and then freed it.
I think you mentioned 2.70 coming soon after website rebuild, so I'll try again then..
Thanks.
Re: 2.60 SIGSEGV 14 years 4 months ago #1947
  • Abdellah Al'Arief
  • Abdellah Al'Arief's Avatar
Yes, i got SIGSEGV too.
My old project, run without any error with old version of Lazarus (but i don't want to use old version of Lazarus).
Now, i got SIGSEGV, my project use interface to encapsulate Zeos component, so it can be freed automatically on runtime.
I did a test to make sure KpjComp statement about TDataset true,
   Fcon: TZConnection;
   Q: TZQuery;
  Fcon:= TZConnection.Create(Self);
  Fcon.HostName:= 'localhost';
  Fcon.User:= 'root';
  Fcon.Password:= '';
  Fcon.Protocol:= 'mysql';
  Fcon.Database:= 'ppdb2011_pontianak';
  Fcon.Connect;
  Q:= TZQuery.Create(Self);
  Q.Connection:= Fcon;
  Q.SQL.Text:= 'select * from bobot';
  Q.Open;
  Q.Free;
  Fcon.Disconnect;
  Fcon.Free;
SIGSEGV error occured when debugger try to execute
Q.Free;
i don't know, this (maybe bug) because Lazarus Bug, Code Typhon Bug, or my code?
i hope Sir Sternas has a solution for this.
Thanks.
altaifa.com
Last edit: by Abdellah Al'Arief.
Re: 2.60 SIGSEGV 14 years 4 months ago #1948
  • 4aiman's Avatar
Have you tried to run without debugger?
Or have you tried to close query before destroying it?
en.wikipedia.org/wiki/SIGSEGV
Last edit: by 4aiman.
Re: 2.60 SIGSEGV 14 years 4 months ago #1952
  • acoliveira
  • acoliveira's Avatar
Sir, try close first, and encapsulate with try/exception (sorry for my poor english)
Re: 2.60 SIGSEGV 14 years 3 months ago #1999
  • Abdellah Al'Arief
I did a simple test
var Q: TSQLQuery;
  Q:= TSQLQuery.Create(nil);
  Q.Close;
  Q.Free;
it can work properly on Original Lazarus (from Lazarus site) and raise an SIGSEGV exception on Code Typhon Lazarus 2.60.
So i conclude, that Code Typhon 2.60 is released with non stable Lazarus version. Then, i'm waiting for next version of Code Typhon...
altaifa.com
Re: 2.60 SIGSEGV 14 years 3 months ago #2000
I think we Solve this problem
with new ZeoDB SVN revision 1288 (trunk)
a big update...
your sample working with out problem
Please, give to my team 1-2 days for test and release CT ver 2.70
after this release we want to start CT Generation III with live updates (rolling installation)
but we will see
Re: 2.60 SIGSEGV 14 years 3 months ago #2023
  • Keith Johnson
Nice one, look forward to 2.70.
That sounds nice :), will this be able to SVN updates, and be able to select revision's etc. That would be really nice.
Re: 2.60 SIGSEGV 14 years 3 months ago #2037
  • Adriano Soares
  • Adriano Soares's Avatar
Version 2.70. Really good news.
Re: 2.60 SIGSEGV 14 years 3 months ago #2043
  • Chris
  • Chris's Avatar
  • Thank you received: 4
Hi Sternas
any update on when CT2.7 will be available?
I need to do some stuff with Zeoslib so I either wait for 2.7 or try and retro fit an older version of Zeos (possibly from CT2.5 as the latest Zeoslib from their SVN doesn't appear to compile in CT2.6 without some other changes and I don't really want to spend time battling with that if you've already resolved those issues in CT2.7).
TheBlackSheep
Re: 2.60 SIGSEGV 14 years 3 months ago #2044
we want to release CT 2.70 tomorrow
Re: 2.60 SIGSEGV 14 years 3 months ago #2045
  • Chris
  • Chris's Avatar
excellent - great news, I'll await the update then.
Thanks Sternas
TheBlackSheep
Re: 2.60 SIGSEGV 14 years 3 months ago #2046
Don't forget
our test circle before every release :unsure:
Win32-Win64-WinCE
Linux32-Linux64 (Debian32/64,Ubuntu32/64,Scientific32/64 and Chakra32/64 for QT)
FreeBSD32-FreeBSD64 (PCBSD)
Solaris32-Solaris64 (OpenIndiana32/64)
Android Arm/i386
many things to do and test...
Re: 2.60 SIGSEGV 14 years 3 months ago #2056
  • Chris
  • Chris's Avatar
hi Sternas
thanks for releasing CT2.70 (you must have been up very late last night doing this).
I noticed the link to the "changes log file" on the home page and on the download page still refer to 2.6 (the "latest version" also says 2.60 even though it's 2.70 now).
Thanks again.
TheBlackSheep
Re: 2.60 SIGSEGV 14 years 3 months ago #2057
we fix download page
please refresh your Internet Browser
for changes log file (Browser cache)
Night or Day is the same for us... :silly:
