"Remove and Build All" failed on Win7X64Ultimate. 14 years 9 months ago #1575
  • xichen li
  • xichen li's Avatar Topic Author
Hello!
I am trying the latest CodeTyphon version 2.40. After I run install.bat of "CodeTyphonIns" package, and launch CodeTyphon using either CodeTyphon_win32.exe or CodeTyphon_win64.exe, I cannot "Remove and Build All" successfully. I have been looking for a solution but most other installation problems seem to be related to 740 administrator rights.
I send the building logs, would you help me?
File Name: log_2012-02-02.zip
File Size:380 KB
Thanks in advance
Last edit: by xichen li.
Re: "Remove and Build All" failed on Win7X64Ultimate. 14 years 9 months ago #1576
C:/Cygwin/rm.exe is the problem
CodeTyphon has freepascal rm.exe to freepascal bin folder
My suggestion is to rename for test C:/Cygwin/ forder (for sample C:/Cygwinzz/)
and try to "Remove and build all" again as Administrator
The following user(s) said Thank You: xichen li
Re: "Remove and Build All" failed on Win7X64Ultimate. 14 years 9 months ago #1577
  • xichen li
:laugh:
Thank you for your help very much! ( I did see the "rm.exe" comes from Cygwin instead of CodeTyphon, but overlooked that because I thought that both "rm.exe" may function similarly )
Could you help to comment whether it is possible for CodeTyphon to put its own bin paths in front of other paths automatically?
Could you also comment when I finish building, can I name the Cygwin directory back when coding and compiling?
Re: "Remove and Build All" failed on Win7X64Ultimate. 14 years 9 months ago #1579
  • xichen li
Could you also help to comment the reason and solution of another problem of cross building? (www.pilotlogic.com/sitejoom/index.php/fo...ed-on-win7x64sp1ulti)
